Feature request for datapoints
Hello we have recently migrated to logicmonitor and previously used Check_mk Nagios. I was wondering if there was a way to include a data point for each check that timestamps the last time the check changed state. As an example if I was sending PING checks to a host it would be nice to know at a glance without having to look at a graph when was the last time the PING check went into a CRITICAL or WARNING state.
Miguel_DeCamps
1 comment
Joe_Tran
·9 years agoIf you mean being able to add widgets to a Device Dashboard, then yeah that would be great!
But as a workaround, you could use the Alerts tab or Dashboard's Alert List widget and adjust the filters. Changes in state would be captured there and would be more explicit about trigger times.
