External Ticket ID - Add via REST
LM Team,
I am hoping there's an easy way to do this already. I'm looking to update the externalticketid via a REST API call vs an integration. Is this possible with the alerts REST APIs?
Tom_Lasswell
3 comments
Sarah_Terry
·9 years agoHi Tom -
Thanks, that makes sense. There isn't currently a method for setting the external ticket id outside of an integration - that's all specific to our integration logic. We can consider it for future improvement, however.
Sarah
Tom_Lasswell
OP9 years agoI don't use the built in integrations to create tickets in our ticketing system, I use an external script that polls for alerts and actively updates tickets with additional data.
Currently I use the acknowledge to say a ticket has been created but I like the idea of leaving them unacknowledged with just a note, however this poses some level of issue for what's already had a ticket created. I was hoping to use the externalticketid reference for this. However, I can just use the ackcomment field and that would work.
I could also possibly investigate using an integration for the initial ticket update, but i lose a level of automation that way. It would also require an integration to be created for every one of my clients.
Sarah_Terry
·9 years agoHi Tom,
You can certainly get the external ticket id associated with an alert via REST API, but updating may be trickier. Can you provide a bit more context re your use case on this one?
Sarah
