External Alerting - Script - Medium for self-heal/actions?
I will admit that I had completely forgotten that External Alerting was a thing. When we first started with LogicMonitor (like 3+ years ago), someone at LogicMonitor had mentioned External Alerting as a potential solution for a random use-case and I had immediately disregarded out of hand--favoring a Custom HTTP Delivery integration instead.
Fast forward to now and this a href="https://communities.logicmonitor.com/topic/2245-feed-lm-alerts-to-splunk-tool-excluding-custom-email-delivery-method/?do=findComment&comment=5924" rel="">post, and all this recent talk about self-heal and actions and an idea was sparked.
Some internal partners are building automation tools to resolve issues and are pretty comfortable with some DIY. Originally, I had figured I would have to get them setup with an AWS Gateway+Lambda function that can receive alerts triggered which would then start a cascade of custom code, in the correct AWS VPC, to self-heal--but why bother when we have external alerting right? The client environments that I monitor and that these internal partners manage have dedicated collectors in each client environment. Just assign that client's collector to that client's resource groups, throw in a broker-like script that takes in necessary resource metadata, datasource, and execute the necessary remediation scripts. Disregard any alerts for datasources not supported by our self-healing project.
This assumes that I'm interpreting External Alerting correctly. The key thing for this to work for my use case would be the ability to have External Alerting AND our normal Alert Rules apply to the same resources/alerts. The Alert Rules would still be responsible for delivering the alert to our ticketing system. Timing of when Alert Rules would trigger and when External Alerting would trigger would be nice. The support center page for this makes it seem the collector polls the resource group at regular, but unknown, intervals. The Alert Rules would populate alert with the ##externalticketid## and it would be neat to have the External Alerting also take that in as a parameter to update said ticket.
I would also need to know if the script executed from this is subject to timeouts, concurrency limits, etc or if there is a limit to the number of External Alerting configs.
Am I way off base?
Cole McDonald
·7 years agoIn terms of timing between steps in an escalation, we're using blank steps to create time gaps in the escalation. For instance, AOS services (Dynamics AX) often come up slowly. We'd like our team to be notified of it if it hasn't com back in 5 minutes, then if it's been a half an hour, we need to either notify the customer or generate a ticket. We set 5 minutes between steps, then set them up thusly:
We leave the last bit blank after generating a ticket to prevent the system from sending more tickets through our system (ours is currently driven via email as the escalation chain repeats the last step if left unresolved and unacknowledged.
Cole McDonald
·7 years agoThis is posted with no warranty. Use at your own risk. Don't test it in a production environment:
No, I'm not OCD, what makes you think that? I like neat vertical lines I can follow for reference in my code. This all collapses very nicely in Powershell ISE.
Cole McDonald
·7 years agoI've successfully tested using CredSSP delegation as a 2nd hop solution. This is becoming a viable option (of course, but the time I finish, LM will have added it as a simple in UI solution).
Cole McDonald
·7 years agoI'm in a multi-tenant IaaS windows environment and I'll need to test my second hop authentication to make sure I can get to the servers we're monitoring from the Collector. The External alerting documentation specifically says it runs the script on the collector. As that is the case, I would imagine the script can do anything you could normally do in the script on that collector.
Caveat from the documentation: "You can only have one External Alert entry per Collector." If you had multiple scripts you wanted to be able to run, they'd need to be tokenized, then pushed through a communication script that starts the pertinent script on the collector which then performs the corrective action on the client. With that in mind, I'd like to rally for an external alerting method that would allow the Collector assigned to a device to be passed as a token that can be used to define where a common script would run from to be able to reach the client VM. I also would like them to be able to be a stage in an escalation... potentially using output from the script to inform the escalation chain somehow. At minimum a true/false continue escalation return flag.
Joe_Tran
OP7 years agoP.S. If I have not gone crazy in my line of thinking, please update the REST API Documentation to include descriptions/methods/models etc for /setting/alert/internalalerts resources. ??
