Event Sources
It is possible to get EVENT Sources off the left menu bar and on to its OWN tab on the right side pane?
I.E. between Graphs and SDT.
Mahlon_Greene
Posted 10 years ago·Last reply 10 years ago
1 comment
thanh_rodke
·10 years agoI don't believe this is possible. Graphs, SDT, etc., are all context-driven, based upon what is selected in the left pane.
Can you describe your use case better? Is it just too many clicks to get to something specific?
