Dashboard Linked Clones
Are there any plans to have linked clones for dashboards?
At the moment we create a template dashboard using tokens and then clone them and then update the token to match what we need to.
The problem is if we make a change to the format of a dashboard, we either have to do it on all of them, or delete all the cloned ones and then clone them out again.
It would make things a lot easier if all the clones were linked back to the master, and an update to layout or widgets on the master was automatically replicated to the cloned templates.
Adam_Gent
2 comments
Eric_Singer
I feel your pain, which is why i simply dug into Powershell + the API's to deal with creating and updating dashboards.
Joe_Tran
As I sit here, hitting Clone on a dash for 80+ client-centric dashes, half-way realizing a more efficient way of setting up the filter on a singular widget--I need this.
