Clone Folder Hierarchy
Feature Request - seeking a native/GUI/repeatable process to duplicate/copy a folder structure.
i.e. - if client A's folder structure is created and defined per our company standards. Then, I want to bring on another client and duplicate the folder structure/hierarchy.
Could this be made available define and have a client template?
Will Fulmer
1 comment
Tom_Lasswell
·8 years agoInteresting idea, we currently use the API for this as there are defined properties and things that are set. I'd recommend that you look at doing this programatically instead of using a GUI clone feature. This way you can keep the standard in code and use all the customization can be done there.
