Cisco UCS Manager
For those that are monitoring Cisco UCS, using...https://www.logicmonitor.com/support/monitoring/networking-firewalls/cisco-ucs-monitoring
are you finding that the default mapping sequence of minor and warning are out of order?
def severity_map = [
"cleared" : 0,
"info" : 1,
"condition": 2,
<strong> "minor" : 3,
"warning" : 4,</strong>
"major" : 5,
"critical" : 6
]And perhaps making the above point somewhat moot, that the thresholds are too low out-of-the-box?
Quote
- You monitor all faults of either critical or major severity status, as immediate action is not required for minor faults and warnings.
- You monitor faults that are not of type Finite State Machine (FSM), as FSM faults will transition over time and resolve.
I know we can tune these and filter out the FSMs, curious if these defaults make sense to anyone.
Thanks - Dave
David_Morgan
0 comments
