BigFix Patch Status
NZRCTG
This datasource will automatically connect to your BigFix server and gather a count of the fixlets that need to be applied. This uses the BigFix REST API and requires the following device properties to be set:
bigfix.url - The URL of your bigfix server (for example: "bigfix.contoso.com")
bigfix.port - The bigfix API port (default is 52311)
bigfix.user - Specify a read-only user with the proper rights as documented here: https://developer.bigfix.com/rest-api/prerequisites.html
bigfix.pass - The password for the bigfix account you are using
The datasource does not have any alerting set up, but you can set your own thresholds.
Brandon Woods
0 comments
