best answer for continous dns latency monitoring
Has anyone set up a check in LM for DNS latency monitoring? What is the "Best Practices" for such a setup?
bthuringer
5 comments
Andrey_Kitsen
·9 years agoIf using a Linux collector, you can use the 'dig' tool as well.
Tom_Lasswell
·9 years agoWould using something like this example work for DNS latency? This would of course be from the perspective of the collector:
https://www.logicmonitor.com/support/datasources/groovy-support/dns-scripting-methods/
bthuringer
OP9 years agoThat is a negative.
Josh_Cox
·9 years agoDid you come up with a good solution for DNS latency monitoring?
