Alert clustering based on matching datasource instances across grouped devices
I have a device group that has the same datasource applied. This datasource auto-discovers and will spin up matching instances across all devices in the group. I would like to have clustered alerts based on the matched instances across all devices in the group.
For example, (pardon the ASCII-like visualization)
ClusterGroup
|__ Device1
| |__ DatasourceA
| |_ Instance_ABC
| |_ Datapoint_I
| |_ Datapoint_II
| |_ Instance_DEF
| |_ Datapoint_I
| |_ Datapoint_II
| |_ Instance_GHI
| |_ Datapoint_I
| |_ Datapoint_II
|__ Device2
| |__ DatasourceA
| |_ Instance_ABC
| |_ Datapoint_I
| |_ Datapoint_II
| |_ Instance_DEF
| |_ Datapoint_I
| |_ Datapoint_II
| |_ Instance_GHI
| |_ Datapoint_I
| |_ Datapoint_II
|__ Device3
|__ DatasourceA
|_ Instance_ABC
|_ Datapoint_I
|_ Datapoint_II
|_ Instance_DEF
|_ Datapoint_I
|_ Datapoint_II
|_ Instance_GHI
|_ Datapoint_I
|_ Datapoint_II
If Instance_ABC's Datapoint_I is alerting at the specified cluster threshold in my hypothetical group, I want to generate a cluster alert. If some time afterwards, the situation in my environment gets worse and Instance_GHI's Datapoint_II is alerting at the specified cluster threshold, I want another cluster alert for that instance-datapoint as well.
Joe_Tran
Posted 9 years ago·Last reply 7 years ago
1 comment
dcorbett
·7 years agoBringing this one back up. If I have one resource accessed by multiple devices, and therefore monitored on them, I don't wan't an alert per device. The only option on cluster alerts at the moment would mean looking at all instances, so I can't build a cluster alert per instance as I would require.
Doing this through service insights would have the same effe
