Add one-click ACk link column to Alerts widget
We would like to see a column in the Alert widget which can be used to perform a one-click acknowledgement of the alert. Perhaps the severity column could double as this function since it already shows a check mark for acked alerts? If it is an extra column, then the column should not take up too much real-estate, so perhaps use small icons as the ack link.
Opening each alert to ack requires 3 mouse operations, and is frustrating if the Alert widget refreshes while an alert property view is open, since it immediately disappears.
We have a need to quickly acknowledge lots of alerts. In the Alerts page there are selection checkboxes, but the Alerts page lacks a global system wide filter to enforce the same view for all operations staff.
jacob_shields
·9 years agoI agree with the usability on that - we see hundreds of alerts sometimes in a day. Our only work around right now is to go to the higher group level and acknowledge en-mass at that level. I like your thought on the functionality of it being useful right from the dashboard/widget.
