Matt_Taylor's avatar
Matt_Taylor
28 days ago
Monitoring Cisco ASA in multi-context mode
We have several Cisco ASAs which run in multi-context mode.
Is LogicMonitor able to automatically discover and populate the contexts for each device or it is necessary to manually add every context to LM as a separate resource?
Having read around, I can't find too much on the subject so I'm expecting the latter, but an answer one way or another would put my mind more at ease.
Matt
1 Reply
  • Hi Matt,
    At present, LogicMonitor does not automatically discover and populate individual contexts on a Cisco ASA running in multi-context mode. Each context operates as a virtual firewall with its own configuration and SNMP context, so you’ll need to add each context manually as a separate resource in LogicMonitor.
    To monitor each context effectively, you’ll:
    Add the ASA multiple times to LM once for the system context, and once for each user-defined context.
    Use the snmp.context property on each resource to define which SNMP context LogicMonitor should query.
    There’s no built-in automation yet for pulling all contexts dynamically, but once set up, you’ll get granular visibility per context, which is often more useful operationally.
    Hope that clears it up!
